Hard drive suddenly stops working, led indicator not flashing.
karel.izaac
My new laptop is acting strange; the hard drive seems to freeze and nothing works when I click on programs or applications. The HDD led is also not flashing, I wait for couple of minutes and the hdd starts gearing up. This problem occurs when the laptop is not active, I ran diagnostic tools and the hdd seems fine. What is the problem here is the hard disk faulty?
Ascendant001
always post screenshot of softwares like crystaldisk info(use portable zip version with no need to install) for hdd related questions.
DK_WD
WD Official
Hi [MENTION=317857]karel.izaac[/MENTION],
I agree with [MENTION=126812]whitestar_999[/MENTION]. To confirm the problem, please share the snapshot of the utility test. I’d like to know if you are using an internal or external HDD? Also, want to check with you, did you make any current changes in the system? Have you tried to connect the HDD to another PC?
