Graphics Problem With My Pc..help
sjk.subhojit
I have pentium 4 2.66 ghz cpu, asus p5rd1-vm motherboard, 512 mb 400 mhz ddr ram, 80 gb seagate sata hdd with onboard 128 mb ati radeon xpress 200 graphics....
I have a problem with my graphics...at first time my pc worked fine. It played the matrix path of neo, gta san andreas, nfs most wanted smoothly (>25 fps) with medium settings.. But right now it gives very poor performance (<5 fps) while playing those games mentioned before.
I have formatted my hard disk, updated my graphics driver....but the problem persists.....what is the solution??.....
And it should be metioned that the windows vista performance rating was 2.0....but now its 1.8
help me!! :(
RCuber
The Mighty Unkel!!!
@sjk.subhojit
Writing in All Caps is Like Shouting
When you write in all capital letters, this looks (and maybe sounds) to the recipient as if you were shouting.
This is why you should
use all caps sparingly.
It is a strong effect, and it should remain one.
Imagine Someone Shouting All the Time
Not only would it mean little when she shouted, it is also more difficult to understand somebody who shouts. Similarly, text in upper case is significantly more difficult to read than lower and mixed case text.
This was for email but applies to forums as well Link
