anilthomas26
first lemme give ma config:
amd 64bit 2800+
1gb ram
evga 6800gs 256mbasus k8n mobo
i noticed this problem after i plugged in a harddisk which belongs to a frend of mine....not sure thought if it is because of this.....
after booting ma monitor jst goes bizzare......full of colours.......nd it happened a few times while working too......
is it some virus prob.....if it was, when i had plugged the harddisk shuldnt ma antivirus have detected that ?? (i use nod32 ).......
or is it a prob with ma graphics card......am having some temp issues with ma card nd i had posted bout that earlier......is ma card breakin down....i seriously doubt that coz i had the "colourfull screen" effect once while i tried to c if ma card was loose or something........
so guys...plzz help me out.......
amd 64bit 2800+
1gb ram
