Fan compatible with Cooler Master CPU COOLER HYPER 212X
noob
I have purchased Cooler Master CPU COOLER HYPER 212X and it came with one fan. I would like to attach one more fan to it which will blow air over the cooler.
Which fan is compatible with Cooler Master CPU COOLER HYPER 212X ?
FYI: I am using Gigabyte GA-B75M-D3H LGA 1155 Intel B75 SATA 6Gb/s USB 3.0 Micro ATX DDR3 1600 Motherboard and CM 430 cabinet.
I want to buy another fan for CM 430 cabinet also.
Both fans should not have any LED lights. I hate it.
How is the 212x performance on i5 2400? What are the temps of your CPU after installing the 212x? I intend to install it on my setup. Do you recommend it?
N
noob
I purchased it because my stock cooler broke. I did not see much difference. The reason i choose this was because its easy to install and i liked it. I am going to add another fan to 221x at opposite end and will check how much the temperature drops.
So far my max temperature is 45 under load. I am happy with it.
