facing problem after using yam in redhat
rajesh_nk22
by mistake i used yam instead of yum.
actually i was tryiing to know about yum, and in the process i did lot of tries in yam, after which i am unable to access my php pages on apache server.
i get this error
Not Found
The requested URL /test2.html was not found on this server.
Apache/2.0.40 Server at yam Port 80
as u see in above line server at yam part 80, earlier it was not like, it use to show name of server as given my me. now its different. please anybody cud tel what is wrong here.
Thanks
ujjwal
I don't know what yam is, but if you login as that same user, and check the ouput of "history | grep yam" here, that will show you the commands you used, and help someone else to debug your problem.
