legolas said:
that is really cool.. but i have some doubts reg. this. actually what u have done? i read that and am in the verge of doing the same.. instead of connecting automatically we ll have 2 click and connect u mean? with that the problem will be solved? is this legal to do?
and how abt the speed? is it still the smae? what is the difference bet what u did and they had(crappy one) is there any use of asking them reg. this?
thanks,
PS: the file for manual setup which u dl in rapid share is no more coz its deleted due to no dl for linger period. pls upload it again. or this is my mail id.
trinity_168b@yahoo.com
/legolas
lol...loads of doubts eh
Will try and answer them all:
Its like combining dial up and LAN. As in I am dialing up into LAN. PPP is a protocol used on for dial up.
Yup. A dial up icon will come onto ur desktop and you will be connected instantly. Its like a direct dial up but on a 128 kbps line
Yup! I use emule, bittorrents and many others and my speeds are consistently aroun 14-16 kbps
And its absolutely legal. You are just combining two protocols to achieve what you want.
consistent speeds for me. No issues there too. No difference if you are downloading using http or ftp. Only problem is with P2P and other networks which need certain ports to be open. And since port forwarding seems to be impossible on Airtels modems this is the only way to achieve it. Oh and no point in wasting your time with airtel guys. They are quite decent in their knowledge but they wouldnt have a clue as to what ur doing. trust me on this
Also this method has several advantages as compared to the USB modem. More free USB port. Also means I can use this on Linux without any issues what so ever.
I dont have the files with me at the mo. Will upload it later and send you the link mate.
