dvd writer problem sony Sony AW-G170A
brijand
my dvd writer does not shows the dvd movie files in the drive but its plays the dvd on the cyberlinkpowerdvd
wats the problem pls tell me
i also cant copy paste the dvd files also due to this prob
hey me too have the same model no...:D
just try playin any other DVD movie..if the same problem is there is not...:rolleyes:
bcoz....sometimes the content is not visible due to problem in file system
but the file is still accessible...happend with my friend also,he played the movie
thru VLC media player...:D
B
brijand
the drive not showing ne files then how can i play it in the vlc player
on autoplay its says the dvd is blank
it only plays on the powerdvd
just popin the DVD...open VLC then select the drive name: like F: etc
it will start playin the data...:D
B
brijand
in vlc also the drive not showing ne files in the drive
its says pls insert a cd or dvd
but prob is not playing the dvd
dvd is playing on the power dvd but
if i have to copy the files it does not showing
that is the main prob
