Dlink dir615 n300 problems
.jRay.
I have the router which keeps on rebooting automatically despite. I tried doing a reset checked the settings but no progress. There was heavy lightning and thunderstorm in my area and the power cable was damaged, got it replaced by a cheap cable from local vendor. Did this cause the problem?
you yourself answered your question.if problem continued even after resetting modem then it is most likely a hardware issue for which you have to visit local dlink service center.
