vi is something that will surely be there, use "vi filename" to edit a file, press to enter insert mode, make your changes, press <ESC> to exit from insert mode, Hit colon (shift + ; ), type "wq" and press enter to save and exit.
Also you have some other easier editors which may be there, "pico" is an example, its pretty easy to use.
And now, in the xorg.conf file it seems the i810 driver is being used. In the video card config of xorgconfig, did you select the proper card you have? Also try lowering the "VertRefresh" option to "50-75".
