Cabinet LED dim
mah_916
I have the NZXT apollo cabinet which as 2 front LED's (apart from power LED) which light up when i start the PC. Here is the picture, the red circle is where the LED's are located
*www2.picturepush.com/photo/a/1119350/220/1119350.jpg
Today when i turned on the PC the left side LED is not lighting up and the right side LED is dim. I have a MSI P45 platinum board with corsair 620 W PSU, to connect the front LED there is separate molex connector that is provided with the cabinet, i checked the manual the connections are all right.
Please Help
Thanks in advance
