comp@ddict
EXIT: DATA Junkyard
By: Hilbert Hagedoorn | Edited by Ant | Published: March 13, 2008
of the guru3d.com team, all credits to them.
*www.guru3d.com/article/building- ... ive-guide/
1.
2.
*www.guru3d.com/article/building- ... ve-guide/2
3.
*www.guru3d.com/article/building- ... ve-guide/3
4.
*www.guru3d.com/article/building- ... ve-guide/4
5. Conclusions
INTERESTING HUH!
1.
So before you lay down a grand on the table, why not experiment a little yourself and build your own drive for roughly 75 EUR ? This way you can at the very least test if SDD is something you'd like, and we'll do exactly that with CompactFlash (CF) memory.
Why using CompactFlash you ask ? CompactFlash defines a physical interface which is smaller than, but electrically identical to the good old ATA interface. That is, it appears to the host device as if it were a hard disk of some defined size and has a tiny IDE controller on-board the CF device itself. See CompactFlash memory this can communicated directly to your DMA IDE interface, similar as the Parallel HDD we all still love so much. So pretty much all you need is some sort of device to make that IDE connection happen, and if you browse a little .. you'll find many of them.
These devices are called CF-IDE converters and if you visit e-bay, search a little .. you can find them dirt cheap. I ordered one through the Dutch e-bay partner Martkplaats, and IDE pluggable DUAL CF (two CFs can be used on this device) to IDE adapter. We can stick two CF's in there and get two SSD drives. There are two type CF 1 & CF II that relate to sheer product size (volume space of the flash). Then there are four main speeds of cards including the original CF, CF High Speed (using CF+/CF2.0), a faster CF 3.0 standard and a yet faster CF 4.0 standard that is being adopted as of 2007. The higher that number, the more expensive and faster the CFs will be.
* Revision 2.0 added an increase in speed to 16 MB/s data-transfer, according to the CompactFlash Association (CFA).
* Revision 3.0 supports up to a 66 MB/s data transfer rate, along with a number of other features.
* Revision 4.0 supports IDE Ultra DMA 133 for a maximum data transfer rate of 133 MB/s.
2.
3.
4.
5. Conclusions
Concluding, now I'm not saying that a CF based SSD is fast enough to replace your current HDD, absolutely not. If anything the results shown today where a bit mediocre. I did expect to gain more overall performance from the RAID0 SSD setup. But this was merley a little test, something I was curious about.
On the other hand, what we achieved here to do today didn't disappoint either as it's ten times cheaper to manage compared to a professional SSD. There is a good reason why the more expensive SSD drives are costing more than 1000 USD, they are just much faster by utilizing the latest technology. Dual-channel setup, internal RAID Flash CF type 4.0 who knows what stunts they pull in these pro SDDs.
Fact is, for a fraction of the price we did manage to make a RAID-0 array with "decent" performance, Windows is heavily recommended. But as a primary drive, I'm afraid this solution is not yet fast enough. Especially since there are screamingly fast solid state drives available these days.
There are definitely alternative usage options you can consider though. Random access/seek time to a SDD is extremely good as there are no moving parts in the SDD opposed to the HDD. And what is the biggest annoyance with Windows ? Exactly, the constant HD swapping causing a lot of delays due to accumulating activity versus seek times.
You could use it really well as Windows temp directory or swap file .. for fast file transfers of big files, obviously you'll need to stick to your usual HD, or indeed that 1200 USD SSD. Then again, a fast flash-disk could help you out there as well. But one thing is a fact, we can achieve pretty decent results with a self made SSD of 70 EUR (including flash), and when you spend roughly 150 EUR, go with the RAID controller and two fast CFs, then things get more interesting instantly as you can go for a 64 GB SDD. When we look purely at the CF to IDE converter with "standard CFs", we noticed slightly slower speeds. But if you plug 2x 32GB on a mobile IDE converter and use it on an average laptop, you might actually enjoy it and preserve a lot of power as these SDDs roughly consume 1.5 Watt.
INTERESTING HUH!
