Building low power consuming NAS
masterkd
Ans: It will be a home made NAS, 24/7 downloader, may turn it into music/video streamer as well later but its not the priority
However as it will run 24/7 power saving capability is a vital point
Ans: As less as possible. I was thinking with 12-13K excluding the HDDs
3. Planning to overclock?
Ans: No
Ans: FreeNAS8
Ans: Planning to start with 1TB x2. Will add later.
Ans: No. Will use existing monitor for setup then no monitor required :wink:
Ans: Monitor, Keyboard, Mouse, ODD
Ans: For now its in RnD phase. But want to buy as soon as possible.
Ans: Lotta times. Will do it myself.
Ans: Kolkata. Open to online purchase
Ans:
1. I was planning to go for embedded CPU systems. Will it cause bottleneck for NAS?
2. Must be mini ITX
3. Most have at least four SATA ports
4. Good to have WiFi (Wiring is a big issue)
5. Power consumption is a huge factor. Having something that uses less than 10W in idle (excluding HDD) and 30 - 40W on load (again excluding HDD) will be really good. But this is also depends on point 1.
6. Will not run any RAID setup.
Intel G2020 (3600)
Gigabyte GA-H61M-S1 (3200)
Corsair Value Select 2 GB 1333 MHZ (1550)
Antec BP300 (2000)
Any local slim cabinet (1000)
Total: 11,350
For HDD, go with WD Green 2 GB (6100) or WD Green 3 TB (8000).
