It will not overwrite/remive PowerDVD. You can do that later if you are happy with VLC. However, if there is an older version of VLC already on your system, that will be removed and the newer version will be installed.
Also give a try KMPlayer. For some videos/DVDs it works smoother particularly if it is HD.
