Yeah definitely there are free and easy to use conversion tools. If you simply want a .avi to .mpeg converter then go ahead to
*www.freedownloadscenter.com/Multim...d_Editors/AVI_to_MPEG_Converter_Download.html
and give your email there, you will get the download link instantly in your mailbox.
If you need any other solution then keep posting.
Regards,
Shovik.
