siddharthmakwana
i m using opensuse 11 and from yesterday i m facing this problem...my DVD and usb are not mounted automatically...
when i insert DVD or pen drive they are not automatically mounted....
this is my fstab...(look like somethings wrong)
(in root)
linux-ziap:/mnt # /etc/fstab
bash: /etc/fstab: Permission denied
linux-ziap:/mnt # sh /etc/fstab
/etc/fstab: line 1: /dev/disk/by-id/scsi-SATA_Hitachi_HTS5416_SB2204SGKAHBHE-part6: Permission denied
/etc/fstab: line 2: /dev/disk/by-id/scsi-SATA_Hitachi_HTS5416_SB2204SGKAHBHE-part7: Permission denied
/etc/fstab: line 3: /dev/disk/by-id/scsi-SATA_Hitachi_HTS5416_SB2204SGKAHBHE-part1: Permission denied
/etc/fstab: line 4: /dev/disk/by-id/scsi-SATA_Hitachi_HTS5416_SB2204SGKAHBHE-part5: Permission denied
/etc/fstab: line 5: proc: command not found
/etc/fstab: line 6: sysfs: command not found
debugfs 1.40.8 (13-Mar-2008)
/sys/kernel/debug: Attempt to read block from filesystem resulted in short read while opening filesystem
debugfs:
linux-ziap:/mnt # hwinfo --cdrom
14: SCSI 100.0: 10602 CD-ROM (DVD)
[Created at block.238]
Unique ID: KD9E.LOUpQL0cx8A
Parent ID: w7Y8.1ythAAgXhH9
SysFS ID: /class/block/sr0
SysFS BusID: 1:0:0:0
SysFS Device Link: /devices/pci0000:00/0000:00:1f.2/host1/target1:0:0/1:0:0:0
Hardware Class: cdrom
Model: "Optiarc DVD RW AD-7530B"
Vendor: "Optiarc"
Device: "DVD RW AD-7530B"
Revision: "NH02"
Driver: "ata_piix", "sr"
Driver Modules: "ata_piix"
Device File: /dev/sr0 (/dev/sg1)
Device Files: /dev/sr0, /dev/scd0, /dev/disk/by-path/pci-0000:00:1f.2-scsi-1:0:0:0, /dev/cdrom, /dev/cdrw, /dev/dvd, /dev/dvdrw
Device Number: block 11:0 (char 21:1)
Features: DVD
Config Status: cfg=yes, avail=yes, need=no, active=unknown
Attached to: #3 (IDE interface)
Drive Speed: 62
Volume ID: "SU1100.001"
Application: "openSUSE-DVD-11.0#0"
Publisher: "Novell, Inc."
Preparer: "CD-Team, *bugs.opensuse.org/"
Creation date: "2008061017282100"
El Torito info: platform 0, bootable
Boot Catalog: at sector 0x0235
Id String: "Novell, Inc."
Media: none starting at sector 0x0236
Load: 2048 bytes
linux-ziap:/mnt # hwinfo --usb
01: SCSI 600.0: 10600 Disk
[Created at block.234]
Unique ID: FKGF.UHL6adcf5V1
SysFS ID: /class/block/sdb
SysFS BusID: 6:0:0:0
SysFS Device Link: /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:1.0/host6/target6:0:0/6:0:0:0
Hardware Class: disk
Model: "Kingston DataTraveler 2.0"
Vendor: usb 0x0951 "Kingston"
Device: usb 0x1607 "DataTraveler 2.0"
Revision: "1.00"
Serial ID: "899801162008011514250FAD"
Driver: "usb-storage", "sd"
Driver Modules: "usb_storage"
Device File: /dev/sdb (/dev/sg2)
Device Files: /dev/sdb, /dev/disk/by-id/usb-Kingston_DataTraveler_2.0_899801162008011514250FAD-0:0, /dev/disk/by-path/pci-0000:00:1d.7-usb-0:1:1.0-scsi-0:0:0:0
Device Number: block 8:16-8:31 (char 21:2)
Geometry (Logical): CHS 1017/125/62
Size: 7888896 sectors a 512 bytes
Speed: 480 Mbps
Module Alias: "usb:v0951p1607d0200dc00dsc00dp00ic08isc06ip50"
Driver Info #0:
Driver Status: usb_storage is active
Driver Activation Cmd: "modprobe usb_storage"
Config Status: cfg=new, avail=yes, need=no, active=u
(in root)
debugfs:
Vendor: "Optiarc"
Revision: "NH02"
Features: DVD
Drive Speed: 62
Load: 2048 bytes
Revision: "1.00"
Speed: 480 Mbps
Driver Info #0:
