audio problem in D101GCC..
ramsingh
i hav downloaded the lastedt audio drivers from intel site nd installed but no sound.. what is d solution?? the audio panel is greyed out...waitng for reply..
club_pranay
Nokia 7110 to iPhone 5
Is it D101GCC? or D101GGC??
check if the onboard audio is enabled from the BIOS.
also, try the last working driver, probably the one you got with the motherboard CD.
