AIRTEL 3G Dongle Problem..
mdp
I have Airtel 3G Dongle (E1731 Huwai) 7.2 Mbps broadband capable.
It works on all 3G Enabled SIM cards such as idea Airtel Vodafone BSNL.
I have used all above cards in my office and everywhere else with same dongle and accessing 3G network very smoothly at office.
At my home PC I am unable to use any of above card as modem gives Error:
"A device attached to your system is not functioning"
and after redialing the modem it gives message:
"The modem (or other connecting device)is already in use or is not configured properly".
The device is not functioning on my home PC only.it works on every other PC.
I have 2 operating systems.
1) Win XP professional SP2 Fully updated
2)Windows 7 Ultimate edition fully updated.
Processor: Intel ATOM 1.6Ghz,Motherboard: Intel. RAM 2 GB, HDD 500GB Seagate.
on both OS modem gets installed successfully.but doesn't work.
errors are enclosed along with as attachments.
Also, I can Access 3G internet with IDEA SIM card through Nokia suite of my phone C5-03 on my home PC.
but when I insert SIM in Airtel 3G dongle, it shows only EDGE network. but contrary on phone it shows 3.5G Network.
I BORROWED THE SAME MODEL NO AIRTEL DONGLE FROM MY FRIEND TO CHECK IF THERE IS PROBLEM IN DONGLE, BUT THE SITUATION IS SAME AS MENTIONED ABOVE.
thetechfreak
Legend Never Ends
Might be something wrong with drivers. Uninstall current drivers and try after installing latest drivers from manufacturer website.
d6bmg
BMG ftw!!
Two instance of the software is running simultaneously and that's the reason behind your problem.
