1. Budget?
60 k
2. Display type and size?
Full HD or 4k
3. Primary use of Tv/monitor?
TV
4. Ports Required?
Atleast 2 HDMI and 2 USB 3.5 MM
5. Preferred choice of brand?
Sony
Sony 42700B -- 60k
LG UB820T -- 59k Flipkart
Panasonic TH-42AS670D 57K Flipkart
Which would be best for watching Bluray movies, play PS3, and watch sports.
I was really confused between Sony 42700B and LGUB820T and while checking flipkart i came across Panasonic TH-42AS670D which has 3D, although not sure about the picture and 3D (Polarized) quality.
I am slightly favoring LGUB820T because of 4k.
Could you guys help and suggest if LGUB820T is bettery buy or i should go for Sony 42700B or Panasonic TH-42AS670D is better value with 3D.
Regards
Vicky
60 k
Full HD or 4k
TV
4. Ports Required?
Sony
Sony 42700B -- 60k
Regards
Vicky
