32 inch LED TV suggestion
1. Budget?
Maximum 15,000
2. Display type and size?
I don't have any idea about LED panels. You be the saviour. 32 inch strictly
3. What will the TV/monitor be used for primarily?
Viewing tv channels (airtel dth) and occasional tv series/movie spree by connecting my external USB 3.0 hard disk
4. Types and number of ports required?
HDMI is a must i suppose, as i have read that content through hdmi is better. USB ports for external hard disk connectivity.
5. Preferred choice of brand?
None in my mind. Open for suggestions.
Nope
Looking for decent/good after sales support.
Brands that can relied upon for 3 years.
I won't be streaming content so smart tv is not needed.
HD ready or Full HD? You tell me which should be preferred.
If a 32 inch monitor serves the purpose, then i am open for it too, unless my connectivity options are satisfied.
If i need to stretch my budget a little for about 1-2k max, which would fetch me a way better product, i can up my budget.
Will be buying online mostly
Minion
Here you go
Philips 3000 80cm (32 inch) WXGA LED TV Online at best Prices In India
If you can spend more you can go with LG 80cm (32 inch) HD Ready LED TV Online at best Prices In India
Just so you know,usb hdd requires much more power than pen drive & not all LED TV models usb ports can provide that much power.Only way to be sure is to take your external hdd & connect it in showroom itself,same is the case with supported audio/video formats in which LG models are almost always the best.
P.S.many TV models also have limitations regarding drive type(fat or ntfs) as well as partition size(some may not support more than 1TB partition,others may not support multiple partitions,and any hdd over 2TB or less than 2TB using GPT instead of MBR will certainly be unsupported at least in lower & middle end models).
R
rakesh-the gilli
Here you go
Thanks. Also, i won't be wall mounting it, so a sturdy base stand is what i will be going with. Have you used these both? May i know why you suggested it.
R
rakesh-the gilli
Just so you know,usb hdd requires much more power than pen drive & not all LED TV models usb ports can provide that much power.Only way to be sure is to take your external hdd & connect it in showroom itself,same is the case with supported audio/video formats in which LG models are almost always the best. P.S.many TV models also have limitations regarding drive type(fat or ntfs) as well as partition size(some may not support more than 1TB partition,others may not support multiple partitions,and any hdd over 2TB or less than 2TB using GPT instead of MBR will certainly be unsupported at least in lower & middle end models).
Okay got it. Will keep that in mind.!
R
rakesh-the gilli
I would suggest vu tv - vfm try to go for 39in model
TCL 81.28 cm (32 inches) L32D2900 HD Ready LED TV
Vu 32 Inch HD LED TV [32D7545]
Vu 80cm (32 inch) HD Ready LED Smart TV (T32S66)
Sanyo 80 cm (32 inches) XT-32S7000H HD Ready LED TV
Have you got any idea about these models? These models were the most suggested in youtube reviews.
chetansha
If you are going to use tata or airtel with HD, then it makes sense to buy full HD.
Vu is strictly for budget conscious, pq and auido is good for that price range.
I have 2 vu at home 40 and 43 . good enough
Sent from my HTC One M9 using Tapatalk
R
rakesh-the gilli
If you are going to use tata or airtel with HD, then it makes sense to buy full HD. Vu is strictly for budget conscious, pq and auido is good for that price range. I have 2 vu at home 40 and 43 . good enough
How about VU's base stand. Are they steady? After sales support?
chetansha
Yes base is steady. Never had a problem with it so didn't need to call service
Minion
They are best within your budget. Philips, I have seen them in chroma they match picture quality of Sony at the very cheap price and about LG their service is good and are feature rich.
Minion
You asked for good after sales support that is the main reason why I didn't suggest them in first place
chetansha
Good dealhere but don't know if we can trust Panasonic
Panasonic 80cm (32 inch) HD Ready LED TV Online at best Prices In India
R
rakesh-the gilli
I went to chroma and checked out the Philips model you suggested. I also did a round up on the VU models. I was satisfied with Philips. VU tv's showed richer colours. But i prefer reliability more. I am about to zero in on the Philips model. LG if i can stretch i will definitely get it. Thanks for the suggestions.
Can we trust Panasonic as cheransha suggested a deal above.
chetansha
I would prefer to go vu or Philips over panasonic
