Gtb93
Hey guys.
I current have a TP-Link wireless router, and a cisco-model cable modem.
Connection: You Broadband pune.
The issue:
The internet works fine when I connect my laptop to the cable modem directly by using an ethernet cable.
However, when I connected the ethernet to the WAN port on the wireless router and try to use the connection as a wi-fi network, it always shows limited access and doesn't connect to the internet. It used to work last week properly, then I had recieved a message from the ISP stating that they're undergoing server maintenance for 2 days. The problem started occuring after those 2 days.
Trouble shooting:
1. I've tried power-cycling.
2. Since I had read online, about the MAC address of the laptop being registered on the cable modem and that it conflicts when the mac of the wireless router tries to get the IP from the modem, I've cloned the MAC of the laptop to the router.
3. Changed the default gateway, factory reset nada nada.
4. Switched off for a day.
I've called up the ISP numerous times, but they keep telling me that their node is working etc etc and that the router is not functioning. (all the lights on the router are still functional). What bothers me is that this error started only after the downtime from the ISP's end.
Any suggestions/solutions guys?
I will be trying out a few other routers which I will be borrowing from my friends.
Regards.
The issue:
Trouble shooting:
Regards.
