Test and Tweak Your Internet Connection for Top Speed
go4saket
9437077259
Don’t settle for out-of-the-box performance when faster downloads and hidden features are just a few steps away.
© First, measure your current connection speed. Make sure nothing else on your network is using the connection and stop any Internet processes on your PC (finish downloads, close your e-mail client, and the like). Next, visit Speak easy’s speed tester at *www.speakeasy.net/speedtest/. Click a server to run the test for download and upload speeds. Note that you will get a typically high results for servers very near you, but that will give you a gauge of your connection’s top raw speed. Try running the test once more against the farthest-away city on the list to see your full range. Try the same test at BroadbandReports.com too, for a good idea of what your current throughput is. If you like to keep an eye on performance over time, the venerable DU Meter (www.dumeter.com) keeps logs of network performance no matter what kind of connection you have.
© You can improve network performance modestly through Registry tweaks, but mucking around in the Registry is never a pleasurable experience, and with these difficult tweaks, it’s easy to mess something up. Tweak Tester makes the task simple. Visit Broadband Reports’ tweak page at *www.dslreports.com/tweaks, and run Tweak Tester II. Results will appear on a new page. Pay attention to the ‘Notes and recommendations’ section of the page, where you will see any settings that merit alteration for improved performance. (You may want to print this page.) Changing the TCP Receive Window setting is likely to be the only tweak that will have any real effect.
© Next, download and run Dr.TCP (*www.dslreports.com/drtcp). You can run the program directly without installing it, but backing up the Registry before you use it is a good idea. (Go to Start•Run, and type regedit at the prompt; then, click File•Export, name the file, and click Save. ) Enter the changes noted in the Tweak Tester results in the Dr.TCP window, and the program will then make all of the appropriate Registry fixes for you. Restart the PC, and then retest your connection to see if the tweaks helped.
© You can also improve your Web experience (but not raw throughput) by increasing the number of download sessions in your browser. By default, Windows limits you to a mere two downloads at a time, but you can bump that up to eight or ten. Since few downloads fill your network pipe completely, the overall effect is that downloads should go faster.
(Warning: Regedit work coming up, so back up your Registry before you begin!)
[1] Click Start•Run , and typeregedit .
[2] Browse to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings.
[3] Right-click in the right pane and then clickNew•DWORD Value .
[4] Type MaxConnectionsPerServer in the resulting field.
[5] Double-click on the new item and then type a new number of connections (say, 10 ) in the ‘Value data’ field. ClickDecimal .
[6] Following the previous three steps, create another new DWORD entry, giving it the name MaxConnectionsPer1_0Server .
Source : March 2007 Edition of PC World, USA
koolbluez
Šupər♂ - 超人
Nice post man...
Some more good speed testers... SpeedTest.net,TestMy.net,Internet Frog,ZDNet Speed Test,YourSpeed,Beeline Bandwidth Test
