Also make sure you keep your computer updated with the latest security patches and updates. You should apply these patches immediately once you use the removal tool to prevent future incidents.
Windows XP - KB835732
Windows 2000 - KB835732
it had happened to me too earlier ! you've been infected with sasser or the lovesan virus. first run your virus scan (avast) at boot time or safe mode using deep-scan modes. then download and use the latest sasser removal tool. then patch up your pc with KB835732 patch. it solved my problem. hope it solves yours too.
