Suggestions required for split AC and washing machine
gopiann
i wanna buy 1.5ton 3 star split AC (copper fins) Budget 32000-36000(38000 max) including installation . can anyone please suggest one good AC. Im from Visakhapatnam. Daily usage upto 6-8 hrs.
And also i wanna buy front load fully automatic washing machine budget 22000-26000.Please suggest which one is good .
thanks
G
gopiann
Does anyone know about trance A/C?
Im thinking about to buy blue star 1.5 Ton 3HW 18 JAR1 .
whatz ur suggestions ? Please share
daily use 6-8 hrs
wide range of ac as over here:
Samsung Purista 1.5 Ton AR18FC3TMUR/NA Split Air Conditioner (White)
Panasonic 1.5 Ton CS/CU-YC18PKY Split Air Conditioner (White)
Samsung S-Purista Plus 1.5 Ton AR18FC3EGBH/NA Split Air Conditioner (White)
YOU can get this at good price also all are with good warranty and branded ac's
