Suggest: Tough Mobile phone with best reception power
Stick
Hello Friends,
Which is Cheapest (Rough & Tough) Mobile phone can hold dual sim (using some adopter cost Rs.25-150) with good battery life & loud ring tone/sound with good signal reception power in low signal area, if have FM will be added advantages.
Just don't suggest over weight modles :(
Thanks :smile:
PS: It's Mendatory for Krazy to post in this thread :D
infra_red_dude
Wire muncher!
I'd suggest Nokia 1112. Compromise a bit on the "roughness and toughness" and you can buy Nokia 2610 (personally I think its looks very ugly!). You can also consider Nokia 6030. The durable color phone with FM (probably the only!)
Stay away from SE and Moto phones in that range, if you want the phone to be very tough!!!
krazzy
Techtree Reviewer
I already replied in the prices sticky thread. I don't feel the need to post the same thing here again. :)
krazzy
Techtree Reviewer
^^ Its on the last page after your post. Did you forget that you posted the same question there too?:shock:
