Speed up MO speed
JohnephSi
GONNA GET ALL OF YOU
Plz guys can u tell me tips to increase the bytes received .4 my MO the bytes received is 1000bytes only and i get speed about 2kB/sec.Plz tell me how 2 increse it ?
Gigacore
Dreamweaver
DAP is not free! Its a shareware. some of the features are disabled in it. but yes you can use shareware to get more speeds!
Pathik
Google Bot
use fdm.. Btw ther s not much u can do.. All r getting low speeds due to network congestion..
ThinkFree
vijay patel said:
U have to DAP (download accelarator plus ) it is free software . u can get speed of 7-15kb/sec . I am also using it .
Don't use DAP. While opened it shows some ads as well and thus it robs you of bandwidth as well as speed. Use free download manager or flashget
Pathik
Google Bot
yup it splits the file into 4+ fragments and dloads each simultaneously.. Get it from freedownloadmanager.org
A
almighty
Guest
r u connecting via cable or bluetooth?
1.use data cable to connect
2.use flashget and set its speed manualy
3.clear ur cache memory of phone...
4.reconnect the net after every2-3 hrs...it makes a diff a lot
try these steps...
