My system specs are as follows:
CPU : Intel Core i5 760
GPU ( Current ) : NVIDIA GeForce 8600 GT
GPU ( Until very recently) : HD 5670
PSU : Zebronics 500W (I can post a picture of the side of the PSU if needed)
Motherboard : intel DH55TC
RAM : 4Gb DDR3
OS : Windows 8 Pro.
So,
I until very recently I had my trusty HD5670 for gaming (Mostly DOTA, LoL or CoD). But It died on me and I had to switch to a temporary card until I got a new one.
I searched around and found that a Pcie 3.0 card will work the Pcie 2.0 slot that i have.
So I decided to get the HD7770 since it was available locally. I got it and uninstalled the Nvidia drivers, plugged the card in and started my system up. There were around 7 static 1-inch horizontal lines on my monitor. I tried installing the AMD drivers and that caused the system to crash every time the setup went halfway.
I sent it to a technician and he did the following.
Jacked up the RAM to 8gigs and used a "platinum series' PSU and that made the lines go away. It also allowed the driver setup to finish but it causes frequent crashes afterwards. Not BSODs, just crashes.
The PSU I had at first didnt have a 6-pin connector and so I used a 2 x Molex to 6-pin adapter.
The technician said that the problem is that the card is too high end for the rest of my system. Now, I'm sure that that is not the case.
The problem is not with the GPU itself as it works fine on other setups( As said by the technician ). It could still be the GPU itself.
My question is, what do I do now? i can provide any more information necessary.
Do I send the card in and get a new one?
Or is the HD7770 really too high end for the rest of my system?
Thanks in advance for any answers
RAM : 4Gb DDR3
OS : Windows 8 Pro.
So,
