slow pc problem not found
himanshurp
i have
AMD FX 8350 processer
Asus AMD/ATI Radeon HD 7770 2 GB ddr5 graphic card
MSI 970A-G46 Motherboard
Corsair Vengeance DDR3 8 GB
and using 600w zeb. psu
with this conf. my pc is slow and web surfing is also slow but gaming is ok ,sometimes it restart automatically plz help friends i cant found problem..
PratikV
OP, How old is your system?.
As all people say, always get Branded PSU for system, cause at extreme load the PSU may not be able to provide sufficient Wattage.
Try the Antivirus / malware software and run it. Have you installed the Graphic drivers properly...
@op; get rid of that crap PSU asap. These crap/local PSUs don't supply rated Amperage and Voltages are also dirty (including random spikes). Get a good quality Corsair or Seasonic PSU.
Sudden restart is generally caused due to overheating. Which cabinet do you have?
rijinpk1
the restart may be occurring due to the psu which does not deliver the amount of wattage you different components needs. you should get a new psu asap for the safety of your pc.
also this does not seem to be a virus problem.
H
himanshurp
i have just buy a month ago and facing this problem as i started it,,as i am using windows 7 and 64 bit os i have just givan my psu to service centre for replacing it
Minion
Change your PSU as soon as possible.download malware byte anti malware scan your computer then download system mechanic free version analyze your system.
