Dear friends,
I am using Nero 7, when i tryied to burn Dvd's, i got the following msg and the burn process failed.
Invalid field in command
Cannot perform start of Disc at once
Burn process failed
I also tried Writing @ lower speeds,but to no avail.
This was the log that was created!!!!
Windows 2000 5.0
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 12:54:32 PM
NT-SPTI used
Nero Version: 7.0.1.2
Internal Version: 7, 0, 1, 2
Recorder: <SONY DVD RW DW-Q30A> Version: YYS3 - HA 1 TA 0 - 7.0.1.2
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <VDRV DVD-ROM DVDR F52>Version: 7.00 - HA 1 TA 1 - 7.0.1.2
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SP0802N IdeChnDr Port 0 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DW-Q30A IdeChnDr Port 1 ID 0 DMA: On
CdRomPeripheral : VDRV DVD-ROM DVDR F527.00 vdrv7000 Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
SONY DVD RW DW-Q30A F: CDRom0
VDRV DVD-ROM DVDR F52 H: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 255MB (261392kB)
Free physical memory: 4MB (4628kB)
Memory in use : 98 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.1.2006
ISO compilation
2:00:43 PM #1 Text 0 File Isodoc.cpp, Line 6411
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
2:00:44 PM #2 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 39936KB of Memory
2:00:44 PM #3 Text 0 File Reader.cpp, Line 124
Reader running
2:00:44 PM #4 ISO9660GEN -11 File Geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
2:00:44 PM #5 Text 0 File Burncd.cpp, Line 3302
Turn on Disc-At-Once, using DVD media
2:00:44 PM #6 Text 0 File DlgWaitCD.cpp, Line 279
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2298031 (510:40.31, 4488MB)
2:00:44 PM #7 Text 0 File DlgWaitCD.cpp, Line 291
Write in overburning mode: NO (enabled: CD)
2:00:44 PM #8 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: SONY DVD RW DW-Q30A, Media type: DVD-R
Disc Manufacturer: TYG02 -
Disc Application Code: 64, Disc Physical Code: 193
2:00:44 PM #9 Text 0 File DlgWaitCD.cpp, Line 458
>>> Protocol of DlgWaitCD activities: <<<
2:00:44 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2298032 (2298032) = #2298032/510:40.32
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2298032 blocks [F: SONY DVD RW DW-Q30A]
2:00:44 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [F: SONY DVD RW DW-Q30A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4706369536, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2298032 | lead-out | 1 | 0x41 | 0x00
2:00:44 PM #12 Text 0 File SCSIPassThrough.cpp, Line 36
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
2:00:44 PM #13 Phase 24 File dlgbrnst.cpp, Line 1725
Caching of files started
2:00:44 PM #14 Text 0 File Burncd.cpp, Line 4132
Cache writing successful.
2:00:44 PM #15 Phase 25 File dlgbrnst.cpp, Line 1725
Caching of files completed
2:00:44 PM #16 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 8x (11,080 KB/s)
2:00:44 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
2:00:45 PM #18 Text 0 File DVDR.cpp, Line 2580
Recording mode: Sequential Recording Mode for Multisession
2:00:45 PM #19 Text 0 File MMC.cpp, Line 21611
Set BUFE: Power-Burn -> ON , Adapt writespeed to disc : ON
2:00:45 PM #20 Text 0 File DVDR.cpp, Line 2735
Start write address at LBA 0
DVD high compatibility mode: Yes
2:00:45 PM #21 Text 0 File Cdrdrv.cpp, Line 8411
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
2:00:45 PM #22 SPTI -1066 File SCSIPassThrough.cpp, Line 323
F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0x53 00 00 00 00 00 23 10 B0 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
2:00:45 PM #23 CDR -1066 File ThreadedTransferInterface.cpp, Line 1799
2:00:45 PM #24 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1799
Could not perform start of Disc-at-once
2:00:45 PM #25 Phase 38 File dlgbrnst.cpp, Line 1725
Burn process failed at 8x (11,080 KB/s)
Existing drivers:
File 'Drivers\IdeBusDr.sys': Ver=7.00.2014, 07/25/2001, size=13366 bytes, created 8/20/2001 12:00:00 AM (Adapter driver for rec)
File 'Drivers\IdeChnDr.sys': Ver=7.00.2014, 07/25/2001, size=79114 bytes, created 8/20/2001 12:00:00 AM (Adapter driver for rec)
File 'Drivers\SCSIPORT.SYS': Ver=5.00.2195.7059, size=74384 bytes, created 7/14/2005 5:54:08 PM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Burn process failed
Windows 2000 5.0
IA32
WinAspi: -
NT-SPTI used
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
19.1.2006
ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Sense Code: 0x24
Sense Qual: 0x00
Existing drivers:
Registry Keys:
