reserve hidden charge when battery it is low for nokia phones
Batistabomb
Deadman Walking
Imagine ur cell battery is very low, u r expecting an important call and u don't have a charger.
Nokia instrument comes with a reserve battery. To activate, key is "*3370#"
Ur cell will restart with this reserve and ur instrument will show a 50% incerase in battery.
This reserve will get charged when u charge ur cell next time.
Akshay
Wht is every1 here falling for??? Nothing like this is possible...
This was a hot topic at many forums n was denied by every nokia expert.
krazzy
Techtree Reviewer
It doesn't work. Period. Whoever came up with this idea should be shot. And if he survives he should be shot again. That code only activates half rate feature which reduces battery consumption by 30%, but call quality reduces, i.e. if you're in a low network area you won't get proper signal. There is another code *4720# which activates enhanced full rate which increases battery consumption by 5% and call quality improves. All these codes only worked in prehistoric Nokia phones like 3310/3315, etc. but is removed in all the later phone. Infact S60 phones never had this feature.
Pathik
Google Bot
Older than that..
This feature was in the all the forums very long back.. but its actually sh1t.
int86
You'r Born Free
This works on older nokia cells like 3310. There is nothing like reserve battery. What cell do is that it consume cell power resulting in low voice quality and less antenna gain.
I am more that sure for this,I can bet fot that.
If I remeber correctly to undo this on has to key in "#3370#"
