problem with TP Link MR 3020 wifi connection
Ascendant001
just like earlier every screenshot of your network status you posted indicates that your net connection should work but it is not.win 7 network status shows as internet access on reliance network,ipconfig /all result shows network reliance as connected & getting ip address & dns servers address meaning dongle is working fine when connected to router.even router is working correctly.btw did you try connecting with router using with lan wire instead of wifi to see if net works.
Ascendant001
i mean first try by turning off wifi in modem & using only lan wire to connect.then turn wifi on & use only wifi to connect(no lan wire connected to modem).in the end try with 2 devices one connected by lan & another(like mobile/ipad) connected with wifi.
