quicky008
I recently purchased a used micromax x600 cell phone from a relative.The device itself is merely 2 months old.I have been facing a peculiar problem with it from the very day it was bought.Whenever I connect it to my PC via the bundled usb cable and select Mass Storage from the phone,its internal memory and the memory card installed in it(2 GB kingston) get detected as two removable drives.When i attempt to check the contents of the phone's internal memory and that of the memory card immediately after connecting it to the pc,i can view all the files on them.But when i try checking them a few minutes after it has been connected,the contents of both the removable drives are shown as blank!Its only after i physically remove the cable and reconnect it to the phone that i can view the contents of those drives once again but strangely,their contents are displayed as blank if i keep the phone connected for a couple of mins. to my pc and then try to access the drives.Can anyone explain why this is happening?
Also while trying to copy a large file to the phone's memory card,an error is displayed after about 50% of it has been copied and then the process halts.This is very annoying to say the least! Occasionally(but not always),i get an error that says "the usb device has malfunctioned" as soon as I connect the phone to my PC but i can still access its memory card and int. memory anyway.Why is this happening?Has the phone developed any kind of fault?The guy who sold me the phone is claiming that it used to work just fine on his pc!
Someone please help me-i require immediate assistance.This problem is driving me nuts!
