Problem while connecting Oracle and VB6!!!
deepak.krishnan
Hello friends,
I am working on my project which makes use of VB as the front end and Oracle as its back-end. My oracle database consists of 2 coloumns named topic and des. This topic must appear in a listbox and when we click a topic the description should appear in a textbox in the form named txtcontent.
(The connection and recordset have been declared in a module)
The codings are as given below:
Dim item As String
Private Sub Command1_Click()
Unload Me
End Sub
Private Sub Form_Load()
con.Open "Provider=MSDAORA;user id=scott;password=tiger;"
rs2.Open "elearn", con, adOpenDynamic, adLockOptimistic
Set lstcom.DataSource = rs2
lstcom.DataField = "topic"
Dim n As Integer
n = rs2.RecordCount
Do While Not (rs2.EOF)
lstcom.AddItem rs2.Fields("topic").Value
rs2.MoveNext
Loop
lstcom.ToolTipText = "Click the topic to view the related information"
End Sub
Private Sub imgexit_Click()
frmintro.Show
Unload Me
End Sub
Private Sub imggal_Click()
frmgal.Show
Unload Me
End Sub
Private Sub imgnb_Click()
frmnb.Show
End Sub
Private Sub imgnet_Click()
frminet.Show
Unload Me
End Sub
Private Sub lstcom_GotFocus()
item = lstcom.Text
Dim rs3 As New ADODB.Recordset
rs3.CursorType = adOpenDynamic
rs3.LockType = adLockOptimistic
rs3.Open "Select des from elearn where topic=item", con, adOpenDynamic, adLockOptimistic
Set txtcontent.DataSource = rs3
txtcontent.DataField = des
End Sub
But when I run this app., I get a error saying that coloumn does not exist and highlights this part of the code:
So Please help me as soon as possible. It is very urgent!!!
DukeNukem
Come get Some
is list box populated with the data Present in the datebase after running the Application ??????
tell me this first
mod-the-pc
Back to School Mr. Bean !
Try this (just copy paste this line in place of existing one)
rs3.Open "Select des from elearn where topic='" & item & "'", con, adOpenDynamic, adLockOptimistic
The query in your code is actually looking for a field named item.
deepak.krishnan
deepak.krishnan
Now the error is gone but when I click a topic the description is not being displayed in the textbox. Is there anything wrong with this part of the code:
Code:
Item = lstcom.Text
rs3.Open "Select des from elearn where topic='" & Item & "'", con, adOpenDynamic, adLockOptimistic
End Sub
(I tried giving it in the click event too but did not work.)
DukeNukem
Come get Some
Write this
as
rs3.Open "Select des from elearn where UPPER(topic)=UPPER(TRIM('" & Item & "'")), con, adOpenDynamic, adLockOptimistic
textcontent.text = rs3!des
deepak.krishnan
deepak.krishnan
DukeNukem said:
Write this
as
I tried doing so
But then an error appears saying that either EOF or BOF is true or current record has been deleted.
It highlights this part of the code:
Code:
It is error no.3021.
What is the problem now???
DukeNukem
Come get Some
remove "textcontent.text = rs3!des" from code to see its effect
what it do is insert the record in the textbox "Simple"
or make the cursor dynamic
deepak.krishnan
deepak.krishnan
But still I am unable to get the description of the topics in the textbox.
For that have I to add something to the code???
If I remove the code:
Code:
then how will I be able to view the content in the textbox???
DukeNukem
Come get Some
Check this code for errors (iam not having VB at home or at Office)
First Make a DSN for ORACLE
Then try This Code (Make Necessary Changes). This will Work For Sure
Public item as String
set con = new connection
con.provider = "MSDAORA"
con.connectionSrting = "DSN=<DSN_NAME>;USER ID = <UID>;PASSWORD = <PWD>"
con.open
FillList
End Sub
item = lstcom.Text
FillText
End Sub
Private Sub FillList()
set ress = new recordset
ress.activeconnection = con
ress.cursortype =adopendynamic
ress.cursorlocation = adopenserver
ress.open "Select topic from <tableName>"
Do While Not (ress.EOF)
lstcom.AddItem ress!Topic
rs2.MoveNext
loop
End Sub
Private Sub FillText()
set ress1 = new recordset
ress1.activeconnection = con
ress1.cursortype =adopendynamic
ress1.cursorlocation = adopenserver 'i think its wrong check for proper option
ress1.open "Select des from elearn where UPPER(topic)=UPPER(TRIM('" & Item & "'"))"
txtcontent.text = ress1!des
End Sub
deepak.krishnan
deepak.krishnan
con.open
FillList
End Sub
item = lstcom.Text
FillText
End Sub
rs2.MoveNext
loop
End Sub
End Sub
But DNS is not in our syllabus and we are not allowed to make use of that!!!
DukeNukem
Come get Some
dim con as connection
dim ress as recordset
dim ress1 as recordset
con.open "Provider=MSDAORA;user id=scott;password=tiger;"
FillList
End Sub
item = lstcom.Text
FillText
End Sub
rs2.MoveNext
loop
End Sub
End Sub
deepak.krishnan
deepak.krishnan
hey found out something
when i tried the same code with emp table there is no error. Is the error related with database structure???
My oracle D/B consists of only 2 fields:
topic
des
topic consists of the headings and des contains the decription of the topic.
