Problem in monitor
m.parthiban
Hi all,
I am using Red Hat 9.0 , my problem is my desktop is not covered fully.
only after 1/2 cm the left margin of desktop begins , so i feel uncomfortable to access the close window buttons when i maximize a window .
My monitor is not automatically detected by Red hat .
Please tell me how to sort out this problem ?
Thanks
M
m.parthiban
Mate thanks for your reply.
I am having dual OS . I tried the option u told already , if i change then the problem switch over to Windows OS .
Please Tell me any other alternative solution .
praka123
left this forum longback
For ur problem regrding monitor u need to edit Xfree86 conf file,in /etx/X11/XF86CONFIG(for debian used rh 7.2 longback) and find the line like this
Code:
Section "Monitor"
        Identifier      "S/T 57/56E/V"
        Option          "DPMS"
        HorizSync       30-55
        VertRefresh     50-120
EndSection
refer ur monitor manual for correct hor and vert frequency enter there.restart x server...
