Hi Everyone,
I am going to built a PC from scratch for my work of Lighting & Rendering. Basically my budget is kind of tight. so can you please suggest me if there are any changes needed in my built. Anywhere i can reduce or change or save on.
I will be using Software like Maya (Most), Unreal engine, Substance Painter, Adobe Photoshop & Aftereffects, Foundry Nuke & Katana and Renderers like Arnold, Vray, Renderman, Redshift etc.
- Budget
- Around or below 1 Lakh to 1.3 Lakh
- Which hardware components
- CPU - Intel Core i7 9700K 3.6 Ghz
- Motherboard - MSI Z390-A PRO or any other suggestion
- GPU - Galax GeForce RTX 2070 Super EX (1-Click OC) 8GB GDDR6
- PSU - CORSAIR VS650 SMPS - 650 Watt or any other if you thought
- RAM - Corsair (8 x2 )16 GB Vengeance LPX DDR4 3600 Mhz
- CPU Cooler - COOLER MASTER MASTERLIQUID ML240L RGB or any other suggestion
- Primary storage - 250-512 GB M.2 / SSD, Please suggest ( brand and price also)
- Secondary storage - WD or Seagate 1TB HDD
- Case - Antec Dark Avenger DA601 RGB (E-ATX) Mid Tower or any other suggestion
- Monitor - I have needed for Color works, atleast 100% sRGB,HDMI, DVI ports, 24inches.
- This is my final configuration unless you guys recommend something else . will upgrade the following maybe after 6-8 months
- RAM - may be upgrade to 32 GB
- Secondary storage - will add another TB
- I will buy in Mumbai, also purchase few parts online.
- Mostly PC will be used for:
- Animation(Lighting and Rendering)
- GPU rendering
- Gaming
- Browsing
- Sometimes overnight rendering( yes only sometime)
- Watching HD movies
- My brand preference:
- Not really, but i am opting for Intel over AMD for long term goal.
- My Preferred monitor resolution
- 1920 x 1080
- overclock?
- Ram might , CPU mostly No
- Operating system to use with this configuration?
- Windows 10 64 bit
- Linux - CentOS (might install after few months of use)
