Please suggest a good LED monitor for gaming,
akashd
Banned
I wanna change my monitor, currently I am using an AOC LED monitor 20.5 inches E2051f. i wanna buy a good monitor (LED) and i will shift this one to my older pc, suggest some, should be atleast 23 inches..
thanx guyz
vkl
Go with Dell UltraSharp U2311H as suggested by d3p.
It's an IPS monitor,has much better viewing angles and color reproduction
than TN panel monitors.
I doubt you can find a 30 inch monitor at all ;)... Go for the dell or go for this
Philips IPS LED monitor E-line 21.5 54.6 cm
If you are on a budget, this seems like an excellent deal :O
A
akashd
Banned
thats just 22 inches, 20.5 is wat i m using right now bro, i need something bigger and better
yochan
check out benq GW2450hm cheaper than dell u2312hm & asus pa238q...but a lot better than both of them or any e ips pannel. gw2450 is a va pannel 5000;1 contrast ratio n 4ms gtg response time
A
akashd
Banned
thanx for the suggestion boy, but i told before that I wanna purchase A LED monitor,
