Please suggest a configuration for 3D Studio Max and AutoCAD
Intel Core i5 4440 -12000,
Gigabyte GA-B85M-D3H -5500,
Corsair Vengeance 1600Mhz 4GB -2800,
Corsair VS550 -3600,
WD Caviar Blue 1TB -3800,
Zotac GTX750Ti 2GB -12300,
Dell S2240L 22" LED IPS -8200,
Corsair Carbide SPEC-01 -3600,
Asus 24B5ST DVD-RW -1100,
Logitech Z313 2.1 Speakers -2100,
Logitech MK200 -700.
TOTAL -55,000.
Cilus
laborare est orare
^^ Bavusani, try to follow the forum rules and let the op answer 1st instead of jumping to suggestions.
E
Eager_Beever
Ans: Mostly 3D Design works using softwares 1. 3D Studio Max and 2. AutoCAD
Ans: Budget is around 45,000/- but can manage around 10,000/- more (if absolutely necessary). A bit tight on budget at present. (Sorry for the wrong budget mention in the original post.)
3. Planning to overclock?
Ans: No.
Ans: Windows 7 Ultimate x64
Ans: 1 TB
Ans: Would like a 22 inch one and resolution of 1600 * 1024
Ans: I do not need an optical drive as I have a spare one available. Also I do not need any speakers, keyboard or mouse.
Ans: Next 10 days.
Ans: I can do the assembly myself.
Ans: I am from Bargarh town of Orissa. I would like to purchase from Bargarh or Bhubaneswar. I can purchase a few items online if I get a better price.
Ans: No.
rijinpk1
fx 8350 - 12.5k
Gigabyte GA-970A-DS3P @ 5.8K
Kingston HyperX Blue 1600MHz 4GB X 2 - 5.3K
r7 265 - 12.5k
WD Caviar Blue 1TB - 3.8K
Cooler Master Elite 311 Cabinet - 2.3K
Antec VP550 PSU - 3.6K
dell s2240l - 8.6k
vkl
Replace PSU/name by VP550P.For the mentioned software I think nvidia counterparts would be better especially for autocad.
Gtx 750ti would be a better choice for 3d in autocad.
Ans: No.
Ans: 1 TB
Ans: Next 10 days.
Ans: No.
Intel Core i5 4570 -14000,
Zotac GTX750Ti 2GB -12500,
Corsair Carbide SPEC-03 -4600.
TOTAL -55,000.
Cilus
laborare est orare
Here is my suggestion:-
FX-8350 @ 13K
Corsair Value Ram 8GB X 1 1600MHz @ 5.3K (http://mdcomputers.in/products/ram/corsair-ram-value-8gb-ddr3-1600fsb.html)
WD Caviar Blue 1TB 7200 RPM SATA 6 Gbps @ 3.8K
Transcend 128 GB SSD (TS128GSSD340) @ 4.88K (http://www.flipkart.com/transcend-1...=b_3&ref=a12b537d-1d9b-45f5-a39a-6df07d5a1b10)
Cooler Master Elite 311 Cabinet @ 2.2K
Asus GTX 750 TI 2GB DDR5 @ 11.75K (http://vedantcomputers.com/index.php?route=product/product&path=201&product_id=1050)
Dell S2240L 22" 1080P IPS panel display @ 8.4K
Total: 49.83K or 50K
Here I have included a cheap but reliable 128GB SSD and nVidia's latest Maxwell architecture based Graphics card which improves in both gaming and Compute performance. SSD will help you in boot time and while working on complex 3D models if placed in SSD due to their low access time.
3DsMax uses iRay engine which is very much optimized for nVidia CUDA and even nVidia gaming cards perform very good in 3DsMax rendering. So suggesting nVidia solution over AMD.
E
Eager_Beever
Thanks for all your suggestions. But AMD processors and motherboards are not easily available in Orissa. Can you please recommend any Intel Processors and motherboards? (Personally I have always preferred AMD over Intel due to performance and cost factor. But AMD has a smaller presence here nowadays).
Cilus
laborare est orare
Buddy, I am living in Orissa for last 6.5 years and built 4 AMD based configurations, starting from Phenom II X4 955, then 1090T, FX-8150 and now FX-8350. You can get Asus Motherboards from Saheed Nagar with ease, just contact Rashi peripherals. For Processor, you can order it from Online shop like smc international directly. Also you can get them from Kolkata based Online stores like mdcomputers.in or vedantcomputers.com
