I need help in buying/building a new PC. My budget and requirements are as follows:
1. I myself have built systems and know how to do it. I want input on current high performance, good value components;
2. Thinking of going for a SSD -for OS & a WD Black 1TB or 500GB drive to Data Storage.
3. The work involves creating 3D plans for a building, structure and use V-ray and other tools/ plugins( I am not expert in design or any kind of Adobe software, I am passing this info from my cousin) to add textures etc.
the expectation is the system should be stable.Stable = the system that does the job without hangs , delay ( taking too much time to do the job). Does not have to keep tinkering with hardware to fix issues such as harddrive failures which inturn in data loss....I cannot be anymore specific than this about the kind of usage for this system ..probably I will get it from cousin later.
Should I go for Custom Built or pre-built / Branded ones like HP, Lenovo, Dell etc?
I request you input / help in getting a good system.
- Budget: Rs.55000 to Rs.60000
- Existing hardware setup: Nil
- Components from the existing setup that you intend to keep: nil
- Components that you have in mind for your new PC: Intel Based I5.
- Plans to upgrade in the future: No; May be RAM & OS to Windows 8 Pro
- Places from where you will buy components along with your location: Bangalore-S.PRoad, Chennai-Ritchie Street, Online whichever is cheaper
- Are you comfortable with buying secondhand components from the Erodov market? : may be
- Intended use of the PC [gaming/office use/rendering/HD playback etc] : Graphics processing,Architecture softwares, AutoCAD, 3D Studio Max with VRaY and other plugin photoshop etc.other purpose include using it for internet browsing, downloading, Microsoft office, watching HD movies, songs etc; NO Gaming. May be small kids games, like Bookworm deluxe, AngryBirds etc.
- Brand preferences:Intel Based system; PSU - branded one; The casing should be really a good one for Aircooling;
- Monitor resolution and size: 22 Inch Monitor
- Will you be overclocking your setup?: Not at all.
- Which OS will you use?: Windows 7 x64 bit Ultimate
