Need Help with Scratch on monitor
beingGamer
I know this is a tutorial section, but posting it here because maybe the suggested solution would become a tutorial.
I have Dell S2240L monitor. today morning i noticed there is a scratch on the little-lower left side of the screen. its not visible in games but when the background is uniform, like if a browser or folder browser is opened under it.. its visible.
Is there any way i can make it unnoticeable ?
Vyom
The Power of x480
What do you mean "scratch" on monitor? Can you post a screenshot? Are those dead pixels? Or is the screen starting to crack?
jalal
There are many liquid which can help you for this. You can go to market and buy it. I think this can remove your tension, Thank you.
