gxsaurav
You gave been GXified
Ok, first of all, I m not a programmer so my knowledge of programming in JAVA is 0.
What I have here is a JAVA based Yahoo messenger client application in .jar format, for my mobile phones K750i. The application works fine, but there are a few shortcomings in it such as UI for phones with 176X220 resolution etc.
Since the GUI of this app uses only some images & most part of the GUi such as gradient are “coded” I guess I can open it in some JAVA IDE with GUI where I can see the preview in a window & edit the code to change the colour etc. Is this possible?
Is there any JAVA programmer willing to help with me here? I can provide the application & since it is JAVA you can also run the jar file in your pc (don’t know how to) to see how it looks, I can give you what to change; you just have to code it. Or just recommend me a JAVA GUI designer application, which I guess is Netbeans IDE with Mobile pack (that is the only one I have heard about)? I also saw JFrom designer but don’t know which one will do the job cos, like I said, I m just into designing here & no coding.
The application YMess, based on jYMSG API. Now making a whole new application based on this API is tough task that’s why I decided to modify an existing one only.
The things which we need to do is[FONT="]
[/FONT]
[FONT="]1) Increase the font size or give an option to user from choosing multiple font size from a menu.[/FONT]
2) When the user receives a message the LCD of mobile phone flashes 3 times. I have to remove this flashing with either nothing or a small audio file.
3) Many other UI enhancement for phones with 240X320 resolution.
[/FONT]
