Harsh Pranami
I purchased this modem about 4 months ago. Since then I've been regretting my decision. My laptop is g6-2005ax. When I plug the modem in usb 2.0 or usb 3.0, the dashboard boots up fine and shows the signal.
*img855.imageshack.us/img855/920/puf9.jpg
But just after pressing the connect button, this happens.
1) When the modem is connected in usb 3.0 port
*img16.imageshack.us/img16/1892/yc1t.jpg
2) When the modem is connected in usb 2.0 port
*img839.imageshack.us/img839/3010/5t1h.jpg
I'm able to successfully connect only when the modem is connected to usb 2.0 port AND the windows displays the error that a "high speed usb device is plugged into a non high speed port. Please connect it in one of the following usb 2.0 port". The problem is, sometimes it takes 2-3 hours for this error to appear and sometimes it doesn't appear even after multiple restarts. I had this problem in win 7. I did a clean install of win 8 and the problem still persists. ANother G6-2005ax+huawei e303c user Chaitanya had this issue, but it got resolved when he moved to win 8. Mine didn't. I'm using the latest driver by huawei. Please help. Pleaseeeeee
