Well, I never traveled via Flight and I'm having a hard time understanding few procedures.
To start with, the simplest thing, booking a flight. When I'm searching on *book.goindigo.in/, I'm being offered two columns of fare - Regular Fare and Return Fare. But the catch is the site is divided into two parts Deperture and Return Journey. So on both the part they are showing Regular Fare and Return Fare.
If you check the image below, the upper section shows fare for Onward Journey which is again divided into Regular and Return Fare. So I think the fare on Return Fare column is the fare I'll have to pay for both Onward and Return flight.
But then again I'm getting confused, as the below section shows flights for Return Journey which is again showing both the fare.
Can anyone experienced travelling in flight explain the thing?
*i.imgur.com/ilhGNjj.jpg
Once this is cleared, I'll go for next one
