i am going to buy 1.> Athlon 3200+ 2.> Asus a8n-vm csm i can't go for all the high end cabinet( which seems to be good in every aspect) mentioned in the forum. so i will buy a cabinet available locally. I want u ppl to plz suggest me 1) what are the constructional details that i should look for, in a good cabinet? 2) i have heard that the northbridge (particularly in this mobo) heats up considerably (although passively cooled), so plz suggest a solution? 3) Any other advice that u would like to give.
get a zebronics antibiotic cabinet .. its very decent. more than the cabinet concentrate on getting a good powersupply. dont trust the local psu's which come bundled with the cabinets. get a good branded psu such as powersafe or antec or zebronics.
Are you sure zebronics is good ?? I have a zebronics PSU , although it didnt give problems till date but i have heard other people having probs with it
hmm i am using a zebronics 640w psu (skyhawk oem) and this psu rocks... zebronics is selling some quality stuff though i really havent used their lower end psu's but i think they will be better than the local companies anyday.
Ya definately zebronic is good... BUt better is VIP cabinets... If ur lagging in money then go for Antibiotic frm Zebronic Please mention ur budget for cabinets n PSU both...
my budget is 2000 Rs. i Don't think i ill get all this stuff in my area, may be i will get it in raipur. i am getting here frontech, intex, and noname cabinet
you can get Zebronics in Raipur now. they have started operations from April 1st 2006. Are you buying your system from Raipur or Durg ?
hey nd4spd please dont go for Intex/Frontech/Iball...they suck Go for at least Zebronics or Navtech 8)
@mohit anywhere i can get good quality goods. @royal thanks for ur advice, but can u plz specify in which term they r lacking? or as u said "they suck"
i -ball has got good looks but very flopp body... its totally made of "patra" Also the PSU tends to fail within a year N About frontek n intex... they neither have looks nor good body... dont know abt their PSu...
