Need Help in chooseing a decent mb and a cooler
Crazyguy48
:-| Hi guys me decideing to buy a new pc
my conifig is as
Pros :AMD Phenom™ II X4 965 BE(overclocking to 4ghz for good performence)
GC: thinking of cross fire with a decent Nvidia for Pysic supp & AMD for graphics
CAbinet is ANtec 900
MB-?
Cooler-?
P.S-?
which to buy?:?::?:
mavihs
Techie By Heart
Can you fill the below questionnaire so i can suggest you a good config!
1. What is your MAX budget?
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
4. Planning to overclock?
5. Which OS are you planning to use?
6. How much hard drive space is needed?
7. What resolution will the screen run at?
8. How would you rate your hardware knowledge from the count of 1-10? (1 being the lowest, 5 being you are somewhat in sync with the current performers and 10 being the highest)
10. When are you planning to buy the system?
11. Are you one of the types looking out for "future proof" configurations?
12. Are there going to be any components that you don't want to include in this new rig? If yes, do mention.
13. Which city do you live in and are you open to buying from shops from other city/states?
14. Mention any other points if deemed necessary
C
Crazyguy48
1. 1 lack
2. Hm i dont knw what that means
3. Gameing movies
4.ya(only the pros)
5.win xp/7and linux
6.1 tb
7. Am buying a 22 inch moni
8. 6
9. Ya this wil be my second
10. I can w8 for a year til me satis for what i am buying
11.ya
12.no
13. Chennai am open to buy any place tht offers good service
14. looking for a blue ray drive instead of dvd. Plz suggest me a full pc cofig based on this
mavihs
Techie By Heart
you already have this or planning to buy?
you can't run AMD & NVidia cards together! CF is for AMD cards only & there is SLI which is for NVidia cards!
already have it or planning to buy?
Mobo: Asus Crosshair IV Formula
HSF: Thermalright Venomous X/Cogage Arrow
SMPS: Corsair TX650W
RAM: GSkill RipJaws 1333MHz CL7 4GB Kit
GPU: MSI 5870 Lightning
HDD: WD 1TB Black
When you planning to buy? Also Asus CHIV comes on order & takes around 3weeks to get here!
