nac
I am using a desktop, so wired modem is fine and good. But if the price difference is not much, wireless is OK too... (but I should able to connect my desktop which doesn't have wifi signal receiver
Budget - as low as possible (lets say I don't find anything under 900/- but that does have only one port, I prefer to have more than one port. So that I can transfer files from one pc to another if I ever needed. But this put me in a place where I need to spent about Rs. 1800-2000/-
I checked these models, all the three seems to be similar (I couldn't find any difference in spec or features, may be bcoz I am totally a noob when it comes to computers)
Can I pick one among these.... else you can suggest a better one.
Will be buying locally if the price deal is good, if not will buy from online sellers. Will buy within a week or 10 days.
Reliable brand, good after sales service should be good.
Please suggest/recommend a modem, I am really in need of one... Thank you...
