Need help in buying a 24 inch and a 32 inch TV
suvrajeet
Hi Guys,
As topic suggests I want a 24 inch and another 32 inch TV. The budget for 24 inch and 32 inch is 15k and 24k respectively. Those two are separate budgets and can be stretched for 1-2k more. Am not experienced much about ports and stuff but I would want maximum angle viewing(don't know the term for it) as well as If possible playing movies from USB/HDD(If it exists).
Thanks in advance.
satinder
DELHIITE
Get Micromax 40" TV with warranty of 3years in 25k budget. You can compare it at any big showroom.
For 24 inch I will suggest same strategy.
Get 3years warranty is must as LED tvs are not much reliable these days.
You can consider Toshiba also if available with more warranty.
Minion
Currently Philips is giving 5 years warranty
32 "
Buy Philips 40PFL5059/V7 102 cm (40) Full HD LED Television Online at Best Price in India - Snapdeal
24"
*www.flipkart.com/sony-bravia-klv-2...o=p_2&query=sony+led+tvs&otracker=from-search
