newway01
Hello , check the attached pic.. My display turns into this after about 10 minutes of using. It occurs more frequently if I play videos or use my tuner card.. I have to restart my system to get back to normal. But then again it freezes like these after some 15 minutes or so.. Also if using tuner card, when display freezes, audio is still working.. What may be the problem? ..please help..
My config:
AMD Athlon 3800+ 64bit
ECS RS232 MM Mobo
2x1 gb Kingston DDR2
Onboard Ati 1150 graphics (max 128mb shared m/m)
40Gb IDE+320Gb Sata
Generic psu 450W (new)
Running Win XP 32 bit Build 2600 SP2
My monitor is only 2 months old and is Acer G195HQ model, screen resolution set to 1024x768 @ 75Hz..
My config:
ECS RS232 MM Mobo
40Gb IDE+320Gb Sata
