Hi Guys,
I need some help choosing a good Wi-Fi Router to be used at my Home. I wanna make my Home a Wi-Fi enabled area. I am completely duh on how Wi-Fi Router works except for the fact that I know that it gives you a wireless Internet connection within a specific area range. So I am hoping some of you experts there based on my requirement suggest me a Good Brand but not very expensive Wi-Fi Router.
Now to my requirement
I have a 512 KBPS Broadband Cable Internet connection from a private service provider Hathaway. The total area in house is approximately 1200 Square Feet Carpet area. Which has 4 rooms. I am gonna connect 6 devices on it. Simultaneously or separately. 3 Laptops, 2 Mobile Phones, 1 Tablet.
My objective, whatever Wi-Fi Router I select should not reduce the Internet speed from what I am getting from the service provider. The reception of the Internet connectivity in all the rooms of my house should be powerful enough, to give good speed.
I know one thing there are separate Wi-Fi Routers for MTNL/BSNL service and Private Service Provider. As the MTNL/BSNL Routers also have an inbuilt Modem whereas a Router to be used by a Private Service Provider does not have an in-built modem in it. My question is tomorrow for e.g If I wish to switch to MTNL or BSNL keeping that in mind, Can the Router meant for MTNL/BSNL right now be used just a Router and not a modem with my private service provider and tomorrow if I switch to MTNL/BSNL I already have a in-built modem in it. So that way I will not have to recur double expenses if I switch to MTNL/BSNL.
Guys Please advise !
Thanks in Advance !
Thanks in Advance !
