Hi guys, I'm looking for a 32 inch HDTV that I'll be using as a monitor for a PC that I'm building. Although I have a budget of 30k, I'd appreciate if you could suggest some cheaper alternatives as well.
As I will only be using the TV as a monitor I need a no-frills set. Maybe a couple of USB ports and HDMI ports. No smart TV.
Please suggest some options that I can look into. I live in Delhi and most probably will be buying from Gaffar market.
In case this helps, the specifications of my rig are as follows -
AMD FX 8350 4GHz
Asus M5A97 EVO R2.0
GSkill RipjawX F3-12800CL10S-8GBXL 8GB X 1 1600 MHz CL10
Toshiba/ WB Blue 1TB 7200 RPM HDD
Corsair 400R Cabinet
Seasonic s12 620w
Sapphire HD 7970 Dual Fan Version
Asus 24X SATA Black DVD R/W
Logitech K270 Wireless keyboard
Logitech M950 wireless mouse
AMD FX 8350 4GHz
Asus M5A97 EVO R2.0
Seasonic s12 620w
