anzaan
hi ppl...
i gt a problem. whenver i strart my pc, the monitor stays blank. i gt windows xp in my pc. the windows start properly bt nothing comes on the monitor ( how do i knw windows start properly? the starting and ending windows sound plays n also i m able to turn offf the systme using keyboard remembering the commands...).
i have the plugins everything is ok. i gt a tv tuner attched to my pc. the monitor as a tv works well bt it doenst shows anything on screen when i start my pc. i try to change the moitor bt the problem is same. perhaps the problem is nt with the monitor bt the CPU...
can anyone help waht is going on????
__________i gt a problem. whenver i strart my pc, the monitor stays blank. i gt windows xp in my pc. the windows start properly bt nothing comes on the monitor ( how do i knw windows start properly? the starting and ending windows sound plays n also i m able to turn offf the systme using keyboard remembering the commands...).
also the monitor goes blue then black then blue then black....
what is it????
