sudheep.p.anand
New to this forum
I was build a computer configuration combined with Asrock 990FX Motherboard with AMD FX8530 processor. Even though this motherboard was having 8-pin EPS power connector, I was connecting the SMPS of 4-pin EPS cable, which I was using for earlier PC.
3 month later, I noticed that my PC was powering off automatically in between while working. After I was checked the motherboard its noticed that 8-PIN EPS connector and 4-Pin EPS SMPS connector got melt due to the heat and now no proper contact is happening.
This motherboard still has warrenty period. I couldn't find service center in Mysore for Asrock.
Please let me know, is there any option, I can replace the EPS pin on motherboard, as many of the local computer service shops were telling that, this connector will not be available.
Attached the pic of the EPS connector on motherboard and SMPS.
*i.imgur.com/ppB82Tn.jpg
*i.imgur.com/HTSR2dJ.jpg
Regards
Sudheep
Regards
Sudheep
